What is StarterMonLog.txt?
10 replies · 9,569 views · Started 25 September 2004
I found a file named "StarterMonLog.txt" in my 6600 phone.
I opened it and see following:
25.9.2004 13:21:26
SreenSaver.app exit
d1=0,100,0,1
d2=4896836,9408512
So what's this for? and where does it come from? Can I delete it safely?
I have also found this on my phone, it has only appeared in the last few weeks. I guess a recently installed application creates it, I have not noticed which one, but as your file only mentions screensaver, I can guess it is after the installation of Psiloc Screensaver.
But as the name suggests it is a log of the startup of your phone so that you can see if there are any problems.
I have this file on my phone too
It's in C:\Nokia\
It's contents are:
31.7.2004 22:30:26
NcnList.exe exit
d1=0,100,1,1
d2=1632734,
11259904
11.8.2004 2:55:14
ScreenSaver.app exit
d1=0,100,0,1
d2=1497458,9904128
11.8.2004 2:56:24
d1=0,100,0,1
d2=1497384,9949184
11.8.2004 2:57:37
d1=0,100,0,1
d2=1243126,7925760
21.9.2004 17:44:19
dataconnectionlogger.exe exit
d1=4,100,0,1
d2=2384878,9461760
My file is too long to display here 😊
I haven't installed any screensaver app
This file seems to be related with the Symbian OS ..
It's on mine as well, and it's 1.3KB.
If it is a generic file, then I would assume oxsun's file is approximately the same size, and can therefore be safely ignored.
Personally, I would buy a MMC before I started deleting files the size of 3 text messages if I didn't know its purpose or which application created it.... 🙄
Any file that shows up in the phones default file manager,can safely be deleted,and 'StarterMonLog.txt' is no different. 😊
But wht is it
i mean this file
i too have in 6600 as well as in 7610
My 7610 contains:
13.9.2004 20:59:20
Phone.app exit
d1=0,100,0,1
d2=7073616,8757248
23.9.2004 0:44:20
Phone.app exit
d1=0,100,0,1
d2=6531200,8155136
I think this is a log of crashed apps. The apps in my list are the same I occasionally see have hung at some time.
elton wrote:Any file that shows up in the phones default file manager,can safely be deleted,and 'StarterMonLog.txt' is no different. 😊
I do think so.. 😃
Why my Nokia 3230 display this message on startup. Is there any workaround to overcome this problem. Thanks..
Why my Nokia 3230 display "App. Closed DataConnectionLogger" on startup. Is there any workaround to overcome this problem. Thanks..
