Is it my phone or all 6600 are like this?
5 replies · 1,759 views · Started 25 September 2004
I dont know but 6600 sound seems to be as loud as 3660? And it cant even compare to Samsung, sometimes in shopping complex I cant even hear my Wavs or Midi as my ringtone. Is there any method to louder my 6600 or it is so ?
yes , u can use audacity tool to make the tones louder. try to search for the program in search engines.
Zappa wrote:I dont know but 6600 sound seems to be as loud as 3660? And it cant even compare to Samsung, sometimes in shopping complex I cant even hear my Wavs or Midi as my ringtone. Is there any method to louder my 6600 or it is so ?
shchiam1978 wrote:yes , u can use audacity tool to make the tones louder. try to search for the program in search engines.
You Can Try here Audacity
Okay. I downloaded the software because I too face the same problem and haven't got much in way of a solution even after posting a similar question in 3 different forums. Can anyone now guide me as to how do I increase the tone volume in Audacity? A short step-wise tutorial would be a great help.
You can Cut the mp3 song with mp3 cutter or like other programs related to it.
the on the left side when u Audacity
u can see -........+ error make to plus it will show u frist 0 then 3,6,9 then 12.make it 6 or 9 as to sound quality and then export as mp3 or wav but plzzz reduce the quality of the Wav from prefernce and it will make short in size otherwise to would be in Mbs (even small song)
