i can't upgrade my sx1
5 replies · 3,971 views · Started 26 September 2004
i could realy use help on this one
1) i download the correct patch for my sx1 😊
2)i open it 😊
3)i choose a language 😊
4)i agree with the licence agreement 😊
5)Then iswitch off my phone and then i switch it on with the navikey pressed.on the phone it writes software upgrade. i connect the usb and select continue on the pc.then it writes searching for device and after a minute it writes the mobile phone was not found(9) 😮
What should i do? :banghead: please help me.i use my usb for other things and it works .What should i do? :hmmmm:
When you run the exe of firmware auto a file with .inf extension appyers (Siemens_Sx1swup.inf). Right click with your mouse and setup on this file. This .inf (Siemens_Sx1swup.inf) file Is a second driver of your mobile phone to be recognised from windows. That's all... next run again the software and it starts setup... 😉 Sorry for my bad english...Mike-Dealer
If the USB undetectable after trying to restarting to upgrade (means u press navigator down and switch on phone). If the Win XP, the computer will detect the new usb driver....click the icon to install usb driver and open the one of the files call siemens_sx1 swup.....then it will detect yr usb from your phone....from there the software will auto install to upgrade.
Good luck!!!!
[email][email protected][/email]
I have finally found the solution to my USB dilemna for my SX1. I hope this helps everyone who are having problems updating their firmware.
This works for Windows XP users only.
First, the USB connection needs to work properly in order for the computer to recognize the phone. In this case, SX1 Data Suite and mrouter can read my phone but the Firmware updater doesn't.
Download the latest firmware for the SX1 on the desktop.
On your desktop, click on Start and then Settings to Control Panel. In Control Panel double click on System and choose Hardware tab. Under Device Manager, click on Device Manager window. When you see a yellow question mark under Universal Serial Bus Controllers, that's the culprit and the reason why the USB connection between your computer and your phone is not working. Highlight on the yellow question mark, right click and then choose down to Properties. In there, you will have an option to install the Siemens_SX1swup.sys manually which is located on your desktop. Make sure you continue with the install when Windows warn that USB driver is not digitally signed.
Once it is installed properly in your computer, you can switch your phone back on to Upgrade mode by pressing the joystick and turning the phone on at the same time. Do not press the joystick down like what you do when you're going to your contacts list. You will see on the phone that it's turned on for Upgrade mode.
On your desktop, double click on Firmware update, follow the instructions and your phone will be upgraded automatically.
