Hi everyone,
I`m trying to make a small utility which makes a connection using one of the defined internet accounts in P800, and finally display the TCP/IP Settings assigned from the DHCP server on the provider side, after a succesfull connection.
Basically I want to get the LAN settings - IP address, Netmask, Gateway and DNS that the P800 uses to communicate with the server. What I did so far, was to create a connection, using a RGenericAgent, then connect to a socket server, create a TCP socket. At this stage I tried to use the socket`s function RSocket::Getopt to get the TSoIfInfo or TSoInetIfConfig information, but the problem is that the function always returns an error.
Here the snippet (without any error checking, just to be readable):
RGenericAgent agent;
agent.Open();TRequestStatus status;
agent.StartOutgoing(status);
User::WaitForRequest(status);
if I call agent.Progress at this moment, it returns 1000. What does it mean?
Ok, after that I create a connection with a socket server.
RSocketServ socketserv;
RSocket socket;socketserv.Connect();
socket.Open(socketserv, KAfInet, KSockStream, KProtocolInetTcp);
TSoInetIfConfig ifconfig;
typedef TPckgBuf<TSoInetIfConfig> ifconfigbuffer;
ifconfigbuf package(ifconfigbuffer);
socket.GetOpt(KSoIfConfig, KSOLInterface, package)
and this always returns an error, so I'm not able to continue getting the information packaged in the object package.
Can anyone help? Thanks.
