hey! im wondering if ther is a way to disable the loudspeaker wen a headset is plugged in , the headset im using is the hsd3 , even tho it is not compatible wit N7610 , ther is sound in one earpiece!
If no1 has any info on tht , could sum1 tel me if ther is a mono headset with 2 earpieces for N7610 or just one tht wud work for it! :con?
plz reply soon! CHEERS!!!!!!! 😊
