directly to the point
1. Today morning when I started my world clock pro its not opening at all, the menu screen is coming back. I restarted my phone but of no use. Any one can help me out.
2. I search this forum even other forum but couldnt find the solution for copying messages from phone memory to MMC & Vice Versa.....
Any one can tell me how to do that???
Thnx in advance...
zking wrote:directly to the point1. Today morning when I started my world clock pro its not opening at all, the menu screen is coming back. I restarted my phone but of no use. Any one can help me out.
Thnx in advance...
I had the same problem with world clock. it created a lot of problems and finally i had to re-format my phone. then i couldn't uninstall it....if u r using cracked versions probs will occur..
Regardng msgs...u can set the memory to either phone or memory card but u can't transfer saved msgs from mmc to phone memory or vice versa...u can transfer SIM msgs however to phone or mmc....there is a complicated way transfrrng from mmc to phone memory using fe-explorer but i suggest u don't try it as u could lose ur msgs.
thnx for ur advice & help.
regards
