For some reason I was playing with the phone preferences menu and managed to turn on the incoming/outgoing restrictions for all calls. I did this without being prompted to enter a pin code but when I tried to turn the restrictions off I couldnt. I have tried my usual code, 1234 and 0000 and all I get is a "Network Error" box pop up with "Command Error" inside. So now my phone is completly blocked out. I rang Singlepoint (UK) who said their was no bars on my phone and double checked with Vodafone and they said I should have full access. Can anyone help?
Restricted Calls
1) Go to phone
edit
pref
check aceppted callers, though this should not stop you making calls.
2) Make sure you are using line1 and did not change it to line2.
But this would not stop you getting calls.
Maybe its a mix of the two.
These are phone settings so your service provider would not see these, so its really the only things i can think of.
Hope it helps.
Nah I havnt touched any other settings. They are all present and correct. Its just when I try and change the restricted calls options that it wont access the network.
Ive done a backup to my old settings and it still comes up as restricted calls on. This must mean it is a network error and not the settings on my phone but singlepoint and vodafone say i have no restrictions. Anyone else had this problem?
