Hi!
I have a few problem with sending/recieving data between two phones using a data call.
1) I can get the phones to connect and loan the port (RCall::LoanDataPort), however, on the phone that initiates the call it takes much loger... on the recieving one it takes no time at all, but on the other it takes more than 20 seconds to get to the same point! What am I missing?
2) After the call is established and I try to write data, nothing happens. I first do a NotifyDataAvailable on the recieving end and a Write followd by a NotifyOutputEmpty on the sendeing end. On the recieving end it stops at NotifyDataAvailable... no data arrives. On the sending end the write completes, but it then stops on NotifyOutputEmpty. I have no idea what`s wrong as I do as they do in all examples... (Note: I have tried without the Notify... on both sides with no luck).
What am I doing wrong? Do I need to configure something to make it work?
Thanks for any help!!! (and sorry for all the code!)
Parts of the code:
Code:
/* CDataCall.cpp */
User::LeaveIfError(iTelServer.Connect());
User::LeaveIfError(iTelServer.LoadPhoneModule(_L("erigsm"😉));
User::LeaveIfError(iTelServer.EnumeratePhones(iNbrOfPhones));
User::LeaveIfError(iTelServer.GetPhoneInfo(0,iPhoneInfo));
User::LeaveIfError(iPhone.Open(iTelServer,iPhoneInfo.iName));
TInt line;
if (GetLineL(RLine::KCapsData,line)) // found a data line
User::LeaveIfError(iPhone.GetLineInfo(line,iLineInfo));
User::LeaveIfError(iDataLine.Open(iPhone,iLineInfo.iName));
else User::InfoPrint(_L("Data call not supported..."😉);
iDataCallHandler = CDataCallHandler::NewL(&iDataLine, &iCall);
GetLineL(const TInt& capability, TInt& line)
TInt nbrOfLines = 0;
User::LeaveIfError(iPhone.EnumerateLines(nbrOfLines));
for (line = 0; line < nbrOfLines; line++)
// Choose the first available line
if (static_cast<TInt>(iLineInfo.iLineCapsFlags) == capability)
break;
return line < nbrOfLines;
/* CDataCallHandler.cpp */
void CDataCallHandler::Connect(const TDesC& aNumber)
if (iState == EListeningForIncomingCall) // can we make a call?
Cancel(); // cancel any requests
// Create a new call and dial number
iState = EDiallingNumber;
User::LeaveIfError(iCall->OpenNewCall(*iLine));
iCall->Dial(iStatus,aNumber);
SetActive();
else User::InfoPrint(_L("Device busy"😉);
void CDataCallHandler::RunL()
__ASSERT_ALWAYS(!IsActive(),
User::InfoPrint(_L("ERROR - CDataCallHandler::IsActive"😉));
// Request succeded
if (iStatus == KErrNone)
switch (iState)
case EListeningForIncomingCall :
// Answer the incoming call
iState = EAnsweringCall;
iConnection = EIncomingCall;
User::LeaveIfError(iCall->OpenExistingCall(*iLine, iName));
iCall->AnswerIncomingCall(iStatus);
SetActive();
return; // leave method
case EDiallingNumber:
iConnection = EOutgoingCall;
// fall through to EAnsweringCall
case EAnsweringCall :
// Loan data port
iState = EGettingPort;
iCall->LoanDataPort(iStatus,iCommPortInfo);
SetActive();
case EGettingPort :
// Start the server if necessary, connect to the comm
// server and load the comm module
StartC32();
User::LeaveIfError(iCommServer.Connect());
User::LeaveIfError(iCommServer.LoadCommModule(
iCommPortInfo.iCsy));
// Open communication
iState = EOpeningPort;
iCommPort.OpenWhenAvailable(iStatus,iCommServer,
iCommPortInfo.iPort);
SetActive();
case EOpeningPort :
// Will complete when the current handshaking configuration
// and the state of input control lines would allow any data
// to be immediately written to the serial line.
iCommPort.Write(iStatus,iDummy,0);
User::WaitForRequest(iStatus);
User::InfoPrint(_L("Connected"😉); // ****
// Read/send data
if (iConnection == EIncomingCall) iCommReader->ReadData();
else iCommWriter->WriteData();
// Listen for hook change
iState = EListeningForHookChange;
iLine->NotifyHookChange(iStatus, iHookStatus);
SetActive();
case EListeningForHookChange : // listening for hook change
if (!iHookStatus == RCall::EHookStatusOn) // still connected
// Re-issue request
SetActive();
// fall through to EHangingUp
case EHangingUp :
break; // release resources and Listen for incoming calls
// Stop reading sending data, release resources and listen for
// incoming calls
User::InfoPrint(_L("Disconnected"😉); // ****
iState = EListeningForIncomingCall;
CancelPendingRequests();
ReleaseResources();
iLine->NotifyIncomingCall(iStatus, iName);
SetActive();
// Request failed eg. failed to dail the number
else
User::InfoPrint(_L("DataCallHandler couldn`t complete request..."😉);
Disconnect();
/* CCommReader.cpp */
void CCommReader::RunL()
User::InfoPrint(_L("ERROR - CCommReader::IsActive"😉));
// Request succeded
switch (iState)
case EWaitingForData :
User::InfoPrint(_L("Reading data..."😉);
iState = EReadingData;
iCommPort->Read(iStatus,iData);
SetActive();
break;
case EReadingData :
User::InfoPrint(_L("Data read, waiting for data..."😉);
iState = EWaitingForData;
iCommPort->NotifyDataAvailable(iStatus);
SetActive();
break;
else
User::InfoPrint(_L("CommReader couldn`t complete request..."😉);
/* CCommWriter.cpp */
void CCommWriter::RunL()
User::InfoPrint(_L("ERROR - CCommWriter::IsActive"😉));
// Request succeded
switch (iState)
case EWritingData :
User::InfoPrint(_L("Data written, waiting for transmit..."😉);
iState = EWaitingForTransmit;
iCommPort->NotifyOutputEmpty(iStatus);
SetActive();
break;
case EWaitingForTransmit :
User::InfoPrint(_L("Writing data..."😉);
iState = EWritingData;
iCommPort->Write(iStatus,KDataToWrite);
SetActive();
break;
else
User::InfoPrint(_L("CommWriter couldn't complete request..."😉);
