MMC collapse
2 replies · 1,501 views · Started 27 September 2004
my 3660 mmc collapse cant format when i insert it show system error now the application on my phone cant uninstall without mmc, got any1 can solve my problem?
hantc wrote:my 3660 mmc collapse cant format when i insert it show system error now the application on my phone cant uninstall without mmc, got any1 can solve my problem?
Try formatting the MMC from another phone or from a card reader. Try booting in safe mode as well, (hold pencil key down on start up, you wont know that you're in safe mode) then try uninstalling your apps 😉 Doesnt happen too much of you use purchased softwares. Care to say what app made the mmc corrupt? I think its just a system error from another one of psilocs products. Uninstallers are located on the C: drive but you might as well do a full format, and all. With that i assume you had a back up of your phone, contacts messages pictures etc, cause that will delete them all.
thanks for helping ...i try to install dictionary on my phone..after i install and reboot it..then my mmc start show system error...now i will try to to format my mmc and i trying to get a card reader as well now...hope that can successful format my phone. any way thanks~!
