I accidently deleted swap.mix from the c drive. Is there any way of getting it back? I have FExplorer but can't find the file on the z drive.
Mixpix
Do you mean MixPix? If so, yes.
Restore back-up memory from MMC.
OR, soft format will restore it since it comes pre-installed on the C: drive.
Since both of those methods will delete recent files in your phone's memory, you could always ask someone with a 6600 and FExplorer to send it to you via Bluetooth.
Cheers 4 that but didn't realise that the file simply gets recreated when you create a new 'swap game!
:redface: I should have thought of that :redface:
