Need Help, New User!
1 replies · 1,293 views · Started 27 September 2004
Hello, I just recently got a 3650 and I have a question on how to install all these different softwares, which i need, and what to get started with. Also my main question is when i put a software on the memmory card through a card reader, then place the memmory card back in the phone, how do i get to this to install it or whatever or just in general whenever i put something on the the mmc card how do i open the mmc card on the 3650, i can't find this function anywhere. Please help, and give me some starter info. Thanks
logix wrote:Hello, I just recently got a 3650 and I have a question on how to install all these different softwares, which i need, and what to get started with. Also my main question is when i put a software on the memmory card through a card reader, then place the memmory card back in the phone, how do i get to this to install it or whatever or just in general whenever i put something on the the mmc card how do i open the mmc card on the 3650, i can't find this function anywhere. Please help, and give me some starter info. Thanks
Discussed to death man, but i pity after 22 reads no one helped.
U install softwares using a Bluetooth dongle or an IRDA port or buy a Card reader then plug in your MMC, copying the files there (*.*Sis) which of course you have to purchase or try first or some freewares, then search the forum on how to install and where to find fexplorer, a program you need to navigate through 3650s file system. Pretty helpful if you dont have a Blue tooth dongle or IRDA port, but have a card reader. I hope that helps a bit, but I hope i also gave u a hint that you should also do ur part and search the forum for answers. Chill.
