nokia PC Suit Crashing
2 replies · 2,586 views · Started 28 September 2004
hi guys
sometimes when i go to open up say nokia phone browser it just wont open. this also happens with app installer. and sometimes it just doesnt reconise the phone, but the pc does strll.
i have to restart my pc and then ope up the programms.
ne help plz?
James761 wrote:hi guys
ne help plz?
I have the problem with Application installer i was using Pc Suite 6.2
well i uninstall it and then install it agian i was not getting the problem.
but i have lost the backup which i have made using Pc suite.
The latest version is 6.3 and is available at www.nokia.com/pcsuite I would recomend you use it.
Only select the connection method you are using in connection manager.
Also make sure your mmc has a name!
If all else fails change the com port the dku-2 is using.
