Hello,
Does anyone know how to edit the boot-up for the 7610?
I installed an active java screensaver and now I cant uninstall it because it does not appear to be in the app manager.
I noticed in the system folder there is a folder called bootdata, but when I try to open a file within it, it says (no installed app for this file).
what app do I need to edit these dat files?
Thanks.
if u want to delete that folder try Fx Explorer from www.gosymbian.com
yes but if I delete the whole bootdata folder what will happen?
the phone may not boot at all!
Delete the file or folder related to that Java Screen Saver
if u still confused then Try Format but u loses the data.
Vicky wrote:Delete the file or folder related to that Java Screen Saver
if u don't want to lose your data. before formatting create a backup via pc suite.
u can restore later if u want.
But if he re-store the data the file(Java File) will again re-store.
thanks for your help, in the end I did a global reset *#7370#
its ok now.
hauntedtoo wrote:Hello,Does anyone know how to edit the boot-up for the 7610?
Thanks.
IF its java then it should be in tha apps directory, you know, games then apps, from there it should be able to have the REMOVE command. les get
appman to see the PROCESSES tab, press option then DETAILED INFO, that will show the location of that certain application, from there u can delete it, just be sure to delete any other dependencies if any.
