Hello.I am looking for a wav player that playes files as a mp3 player. Using a playlist i mean. Like ultra mp3 or anyother that uses playlists, but for wavs. Because i found out that by using the codecs in pcsuite, when trying to transfer a mp3 file to my 3660 , the mp3 is automatically converted to wav. The wav is very loud comparable to the mp3 and still at a reduced size - a 4 mb mp3 was converted to a 1,3 mb wav. So, if anybody knows such a players that uses playlists for wav files pls tell me about it. :icon1:
Wav Player
myx wrote:Hello.I am looking for a wav player that playes files as a mp3 player. Using a playlist i mean. Like ultra mp3 or anyother that uses playlists, but for wavs. Because i found out that by using the codecs in pcsuite, when trying to transfer a mp3 file to my 3660 , the mp3 is automatically converted to wav. The wav is very loud comparable to the mp3 and still at a reduced size - a 4 mb mp3 was converted to a 1,3 mb wav. So, if anybody knows such a players that uses playlists for wav files pls tell me about it. :icon1:
Hey myx, why do you need a wav player? You can play wav files if you go to [ Profiles --> any one profile --> personalise --> ringing tone (any line) --> and it appears in the list.] . But you need to set your screen saver timeout to max. 30 mins cos when the screen saver appears, your song stops playing. But why don't you try to search for softwares that can turn off your screen saver in google. Hope this helps ya'!
