Problem about 6600 wavs and midi
1 replies · 1,243 views · Started 29 September 2004
The wavs that I have receive from my nearest Mobile shop is so clear and loud but the wav that I convert from Mp3 is not loud enough and so is my Midis. Most of the time I could not even hear them without setting it to vibrate. Is there any way that I can make the wavs and midi in my 6600 louder? Or what program should i use in my com before sending them via blue tooth to my handphone? Please reply thanks.
kimimaro wrote:The wavs that I have receive from my nearest Mobile shop is so clear and loud but the wav that I convert from Mp3 is not loud enough and so is my Midis. Most of the time I could not even hear them without setting it to vibrate. Is there any way that I can make the wavs and midi in my 6600 louder? Or what program should i use in my com before sending them via blue tooth to my handphone? Please reply thanks.
you can try dBpowerAmp, set it to 8 bit, 16000hz, 1mono or ur not still satisfied with the loud try to adjust to higher... this is for wav tones. 🙄 😊
