i know there is a way to fit a regular mmc in a 7610. does anyone know how and has anyone here done it.
regular mmc in 7610
By force & bending it or buy using a knife to cut away parts of the MMC holder. Neither is really advisable (the former may very well damage the card and the latter is not so healthy to your phone).
why would you want this ? a rs-mmc is not much more expensive - i bought a 512 MB rs-mmc for 77 Euros, i also saw them for 65 already.
Could u please tell me from wher did u buy the 512 Rs Mmc.
is there any internet link.
I saw a 128mb rs-mmc for �20.
The Prices u r saying is so cheap.
could u please tell me also
or put the site name
i brought 256 for 50 pounds.
Yeah, that is a very cheap price! On the original topic, I saw a post on this in Howard's forum for how to get a MMC into a 7610. Do a search there. However, I remember you either have to get the slim battery or do a bit of work on the phone's body. However, it is very feasable.
Harakiri wrote:why would you want this ? a rs-mmc is not much more expensive - i bought a 512 MB rs-mmc for 77 Euros, i also saw them for 65 already.
Can u plese tell me the site where u purchased!!
sidewinderfly wrote:i know there is a way to fit a regular mmc in a 7610. does anyone know how and has anyone here done it.
I've done it. You just have to remove the plastic SIM card holder and file off a little bit the MMC Card; if well done, fits as a glove.
The advantages? Well, you dont have to be carrying the other part of the mini-MMC Card in case you find a friend's computer with a car reader and no bluetooth or cable to transfer pictures. And standard is always better. Although not even close to a budget digital camera, you can actually use the 7610 as your camera and take some really good pictures.
