mp3 to amr
7 replies · 4,335 views · Started 30 September 2004
How can I easily convert MP3s to AMRs? With which program? Thanks
Why bother? The converter rapes mp3s and makes it into a bad sounding amr. Just convert the mp3 to mono and boost the volume. Makes a great sounding ringtone 😃.
silkshadow wrote:Why bother? The converter rapes mp3s and makes it into a bad sounding amr. Just convert the mp3 to mono and boost the volume. Makes a great sounding ringtone 😃.
u r right!
the amr sound quality is tooo bad.
Vicky wrote:Just try Mp3 Cutter and then use Audacity for making loud.
Thanks.
That is the great idea.
WORKS FINE.
ITALY986S wrote:How can I easily convert MP3s to AMRs? With which program? Thanks
