Hey,
Is there a way (or a soft) to connect the modem of the 3650 to a computer using bluetooth???
Coze my 3650 only proposes my to do it using infra red and my computer is equipped BT and not IR i know strange but well..
thanks for your help
Hey,
all you have to do is pair the device to your pc. then go into the decive, and selecting dial up networking, and voila! the pc will connect to the modem using bluetooth.
thom02 wrote:Hey,Is there a way (or a soft) to connect the modem of the 3650 to a computer using bluetooth???
solved the problem thanks
it was just a wrong setting line in the setting of the modem
thom02 wrote:solved the problem thanks
