inside a 6600
4 replies · 2,142 views · Started 30 September 2004
has any1 opened there 6600 up? or know a website about it? i need to sort the vibrate motor out, i can hear it spingin just not virbating then i hit it and it will work a few times. want to get inside and sort it out. if i can
any help
cheers
If the motor is spinning but the phone is not vibrating then the weight has probally just fallen of the spindle,it is easy to access but i dont know how you could re attach it. Good luck
hi sorry to bring up this thread again, but recently i have had the same problem, did u fix it urself in the end?? and if so how and does it now work ???
thanks in advance
Chris
littledude,
I dont know if he fixed it but,its very easy to gain access to the motor to re-attach the weight (if you can) or check the connection,which is just a springy metal strip.
If you need a whole new motor,you can get one from
Uk: here
Or here
