ive found out that using *99# as the telephone number in windows dial up networking uses the phones default GPRS connection, but is there a code to access the phones default high speed GSM connection????? can someone tell me how to do this its driving me MAD! 😡
dial up networking using the 6600 as a modem
Mozzy wrote:ive found out that using *99# as the telephone number in windows dial up networking uses the phones default GPRS connection, but is there a code to access the phones default high speed GSM connection????? can someone tell me how to do this its driving me MAD! 😡
In your modem extra settings: AT+CGDCONT=1,"IP","@@@
@@@= your GPRS APN on your nokia (for example mine is: inte-gprs.mtel.bg)
Bulgaria wrote:In your modem extra settings: AT+CGDCONT=1,"IP","@@@@@@= your GPRS APN on your nokia (for example mine is: inte-gprs.mtel.bg)
i dont want to access my gprs provider i wantto access my high speed gsm connect
(so i can use the bluetooth trick to use my pcs connection then use that connection on my decrepid laptop that cant handle a wifi card)
