OMG I spent 2 days off just to deal with my 6600! I made a virtual serial port via bluetooth connecting from my CNET bluetooth dongle from the usb of my comp to 6600 but it always. With this I cant even use PC suite!! the message always showed as 'Failed : The remote device closed the connection' Come on ! What on earth is happening? I really need some help here!
Cant connect to 6600 using Bluetooth
First make sure the phone and BT connection are pair and set as authourised so that they can connect without prompting.
Then initiated connection from the PC, it will come up with the same error, click OK, and wait a few moments then the phone should connect to the PC, it needs to do it this way.
I find BT the most awkward connection to set up as there are so many bits to check, but when it is setup you should be able to connect like this no problem.
yeah I got that but I should look at this forum before I try so hard... It does prompt the error message and I was thinking what is the error there while it connects before I notice it =p Thanks for your help anyway cheers
