Damn,
i got my n-gage QD back from the Nokia Service center, i was all happy and stuff.
i used the n-gage for _ONE_ day and the @*# has another problem,
i dont know what happend but my MMC card keeps on saying MMC Damaged.
i put it in my pc and even my pc doesnt want to open that thing.
i downloaded various tools, mmc medic , mmc multi format.
none of that programs read my MMC and make windows crash.
Any Idea's Or is the MMC just broke.
Thxs
TaloN 😡
Nobody had the same problem as me ?
I have had a few problems with mmc's in the past not sure if this will help but its worth a try. take out your memory card and turn on your ngage. when the keys flash the lights insert your memory card by leavering the tip under the plastic clips where the reader is. it inserts rather easy. experiment with the timing. You can get past errors with this. depending on your timing it may seem like the card is not inserted but if you goto menu/tools/Memory it will find it and you can format it.
if you gte the timing right you can boot up with all your apps showing and working. It may seem a little dodgey but there is no damage done aslong as you don't ram it in there or something
Primax
