UIQ Core as a text file wanted
1 replies · 1,879 views · Started 01 October 2004
I need the UIQ Core as a text file. I want to edit it with the Text Application in my P900. Or is there another way to read the core file ?
Roman wrote:I need the UIQ Core as a text file. I want to edit it with the Text Application in my P900. Or is there another way to read the core file ?
If you mean Event Core for UIQ by Ewan Spence, the source is included as SCII text in the original ZIP disrtibution file. Just look for the file 'core.tpl' (any OPL source code on the PC has the file extension *.tpl).
If you want to modify and compile Event Core on an UIQ device, yust import 'core.tpl' into the OPL Text Editor (showing up as: 'Program'😉 by selecting: File->More->Import text...' from the menu.
HTH Martin
