Is There any App For sequence mode (6 images in 2 seconds)?
Nokia 6630 is coming with in built this function
i want to know that is there any 3rd party app which can do this.
Vicky wrote:Is There any App For sequence mode (6 images in 2 seconds)?
me tooo want.but didn't find anywhere.
can anyone post a link for this application.
As far as I can see, there is not. However, I have tried two camera apps that do work on the 7610. They are cameraFX and photorite. Check if they have sequence mode. Iolan spy works but it takes pics on a motion trigger and it only supports 640x480. I have been rather dissapointed in camera apps for the 7610. It seems companies are slow to update software. Many of these claim to be 7610 compatible but are not. It is quite sickening that these development companies have not even taken the time to test their app on a 7610 before claiming compatibility. 😞
silkshadow wrote:As far as I can see, there is not. However, I have tried two camera apps that do work on the 7610. They are cameraFX and photorite. Check if they have sequence mode. Iolan spy works but it takes pics on a motion trigger and it only supports 640x480. I have been rather dissapointed in camera apps for the 7610. It seems companies are slow to update software. Many of these claim to be 7610 compatible but are not. It is quite sickening that these development companies have not even taken the time to test their app on a 7610 before claiming compatibility. 😞
i am completely agree with silkshadow.
Have u tried Photographer from Openbit.
I was using in my 6600 and must buy if it works in 7610 properly
Vicky wrote:Have u tried Photographer from Openbit.
i tried it it works fine in my past 7610.
Thanks guys will give that a look.
Photographer has Sequence Mode aka Burst mode?
I use a program called Camera Snapshot, 6 pics in 2 secs but only VGA (640x480)
is it for the 7610 ?
yes you can find it on **** "snapshot"
