changing face plate for nokia6600
2 replies · 3,211 views · Started 02 October 2004
i cant seem to figure out how to remove the current one?
i mean with a nokia 3310 for example it was pretty easy 😊
but with this... i dont know how to.
so can i find a guide somewhere or something like that?
cheers
Nokia 6600 does not support X-Press On Covers.It is a Repair Cover
Avoid to Change urself unless u have a complte knowlegde abt it.
Vicky wrote:Nokia 6600 does not support X-Press On Covers.It is a Repair Cover
nah its dead easy just a faff i changed mine in like 5 mins. you just put a pin or something similar down the holes either side of the battery and feel around for a catch once found puch it outwards which will raise the cover slightly then use your hands with nails (dont use a pin like it says in tutorials cos it minces the plastic) to work your way around the cover and pull it off
the eplacement just snaps right on
