Hi everybody,
using minigps at home with my sendo x (firmware updated) the average signal level is about 20%: in the same conditions my brother's p910 shows 100%!
Is the new firmware update going to solve this??
Bye,
GM
Hi everybody,
Bye,
GM
I am using Celltrack (instead of miniGPS) and this app shows only 47% signal strengh, when sendos signal status bar is full. So I thing that the apps only calculate wrong values.
CellTrack also reports that the battery is only at 57% after a full charge, so I believe the software is simply not reporting values correctly 😞
stuclark wrote:CellTrack also reports that the battery is only at 57% after a full charge, so I believe the software is simply not reporting values correctly 😞
Yes I think so too, the maximum signal strenght measured is 60%, maybe the software is designed for nokia phones.....
Bye,
GM
