Office on firmware v04.14
8 replies · 2,781 views · Started 05 October 2002
I have just recived a replacement 9210 with firware v01.14 pre installed.
When i backed up and installed my 64 mb mmc, The office app keeps crashing saying "applicasion closed application word reason code word reason number 1".
I have tried to resolve this by formating the device and formatting the mmc. Then using the cd rom v1.0 pre install device and pre install memory card. This process has been repeated sevral timesand the same problem persists. nokiasay that the cd rom should be compatable with firmwarev4.14 but i have my douts.
isthe any sites i can download the new office package for pre install mmc
please help mark :-?
Those 1.0 apps are not fully compatible
Download newest apps here
http://www.nokia.com/phones/productsupport/9210/downloads_sw_413.html
[quote="AAY"]4.14???
You sure about that??[/quote]4.14 is an upgrade for Orange Users but I don't know (yet) what it does.
[quote="mbjoinery"]4.14 is the orange firmware version of 4.13[/quote]
Thanks for the info!
Unfortunately it just confirms my suspicions that Nokia has abandoned 9210 users, software updates-wise.
Thanks for the help jep my office apps are running 100%. I downloaded the upadtes as sugested and installed them Bingo!!! It works..
Now all i have to do is put up with my 9210e untill my new 9210i arrives in november.
Has anyone got the 9210i yet in the uk, and does it come with a usb connector or a serial connector? :P :P :P
