Reported Post by jahele
0 replies · 8 views · Started 24 November 2013
jahele has reported a post.
Reason:
Thanks for distributing these info with us! this is a large site. I really like it. articulate gratitude you for the location. May God bless you in all your works.
http://top7mobiles.com/top-list/best-app-to-download-free-movies-on-android/
Post: Info on: Changing Product Code/N8 product Codes
Forum: Symbian^3 phones (N8, C7, C6-01, E7-00)
Assigned Moderators: N/A
Posted by: seki
Original Content:
qucuqum wrote:Guys how can change E7 product code ?
Nemesis , JAF and Pheonix didnt work !
Any other program to change or any one did ?
.. you won't change the product code .. just use phoenix to install a different firmware onto your device.
by using Navifirm you can find and download the files required for the region/language of your choice (if available)
I just checked and the E7 is listed though no PR2.0 files are available as yet.
It is a relatively straight forward process to use phoenix to upload the new firmware - in my experience its best not to have other devices plugged in to your USB ports while doing it.
Good Luck!
