Custom Ring Tone
9 replies · 2,877 views · Started 04 October 2004
question how can I add a File to my RIng Tones??
I received a Sound File, over Bluetooth which is in my SMS Folder.
Now I want this file to be my RIng TOne, how?
Shaggy
Save to phone memory and then move to c:\nokia\sounds\digital then allocate it as your ringtone for the required profile as normal.
PS Check to make sure it is a supported ringtone format by checking the tech specs on sendos website
I searched the forum to find this answer, but what's a bit annoying is that it doesn't say anything about this in the manual!
Sorry this also works,
The correct way to do this really would be to OPEN the message thats in the SMS inbox. The message will then open RECORDER. you can preview the tone and then in recorder you press save. This places the file in the correct place for the user. Using this method means the user doesn't have to use PC connect or a 3rd party file browser.
That's if you receive it by SMS, but if you transfer it from your PC, if you don't know where to place it, it's quite confusing 😞
Another question: How can I change the alarm from the calender? This sound is not mine! :icon13:
I posted a request to change this directly to Sendo.
They have informed me that this information will be considered in future product development.
So at least they know about a little feature we would like and add another plus point to the phones features.
