Playing Videos on PC
8 replies · 2,475 views · Started 04 October 2004
Ive taken some videos on my 6600 and ive put them onto my pc via bluetooth and ive put the on with my mmc reader but i cant seem to get them to play i have the nokia multimedia player installed they just dont work. on my phone it says the format is video/H263-2000 do i need a player that plays them files?? where can i get one??
Any ideas on what i could do will be great
lee
The Nokia Multimedia Player should play them, if they're proper .3gp files.
If it doesn't, you can also try the latest Apple QuickTime.
If QuickTime can't play the files either, then there's something wrong with the files. If you post one as a reply, maybe someone can take a look and see if the file is really OK or not.
Ive tried Apple Quicktime but didnt work again, i cant upload the files for sum reason bt if sum1 was willing to help can they give me their e-mail address and i will send them to you
thanks
Have you tried using Real one player? You may have to download the 3gp plug in but it will ask you this automatically.
As n/a says tho,they should play ok in nokia multi media player,send one of the problem files to [email][email protected][/email] and i will check it out.
No im not using the phillips camcorder, but i think im gonna get it. then i can film for longer and play them on my pc 😊
Lee89,
The file you sent me is of an unknown format,so nothing can be done.
Have you sorted the problem with the above suggestions yet?
