question(s) on seleQ
15 replies · 2,460 views · Started 05 October 2002
hey everyone..
just got seleQ... i stumbled upon 2 folders.. one is image, and the other is image_tn.. what is the diff?
also.. what can i do with seleQ? manage files? delete stuff that i don't need?
any warnings.. eg. don't touch the system files?
cheerio!
for the image and image tn folder
image folder is where ur image file saved
as for image tn folder is where the thumbnail of ur image is saved
thanks for the info - should have guessed that tn=thumbnail
also, what should i do about compress memory? any good? (using seleQ that is)..
please advise!
cheers, mate!
My personal warning is don't fiddle with the SeleQ program files, I played around with them and ended up with a screwed up SeleQ that was half installed and half delted, but does'nt work!!!
thanks for the warning - really appreciate it mate!
then what good is this program then? what can i do with it?
what can I do to enhance performance? what do you know about memory compression in seleQ?
bout the compress memory i think it just compress the RAM not the C drive
umm.. maybe not
but now i want to ask i already registered my seleq and if i want to delete the thing from my phone how do i get the registered version back into my phone. cos i think even if it is the same instalation file and still generates random regeistration number which is diffrerent from the one i;m using
i think if you delete it and try the same registration key you use, shouldnt it work?
but then again, I am not very sure as I am still learning how to use seleQ.
so compressing memory wouldnt cause any problems? is it a significant increase in memory?
Thanks again.
Yeah, cuz ximplify does'nt want it to be cracked or something, and people start spilling free copies that cost them their product!
[quote="😊"]Yeah, cuz ximplify does'nt want it to be cracked or something, and people start spilling free copies that cost them their product![/quote]
waht waht so how if i delete my seleq and install it again into my phone will it work ???????
yes, i believe that if you delete it, and put it back on again.. it will work fine 😉
have you done memory compress? good?
Yeah no problem, i deleted some components then installed it again, it works fine, but trial date is the same 😞
Someone once posted about playing around with the trail version to make it work. He put the date two days after, and the trial period lost two days (logiclly, of course! duh..) But when he put the date two days before, the trail version instantly became expired!!
Those guys and Ximplify aren't easy!
[quote="😊"]Yeah no problem, i deleted some components then installed it again, it works fine, but trial date is the same 😞[/quote]
yeah before i alredy using an expired seleq and tried to unintall and intall it again but no difference btw i just used seleq for 1 day and it expired cos i set the date bfore the day i installed and it shows that the seleq has expired pls register 😃 😃
then i bought the thing
[quote="😊"]Someone once posted about playing around with the trail version to make it work. He put the date two days after, and the trial period lost two days (logiclly, of course! duh..) But when he put the date two days before, the trail version instantly became expired!!
Those guys and Ximplify aren't easy![/quote]
huh that was meeeeeeee 😃 😃
