Stereo output
4 replies · 2,709 views · Started 04 October 2004
I wanna know if there's a stereo output in the 7610 which i can use to ear my mp3 with the caps
The 7610 doesn't have stereo output. If you connect a stereo headset (pop port 6230 headset for example) it will display "enhancement not supported"
Please search the forum before posting.
Ihave the way to listen mp3 in stereo without not supported enhances.U should insert small paper between enhances and mobile.the quanlity of sound will be better.
upharm2001 wrote:Ihave the way to listen mp3 in stereo without not supported enhances.U should insert small paper between enhances and mobile.the quanlity of sound will be better.
I want some pictures of that.
Someone wrote on some post here that there's an n-gage adapter from pop-port to normal headphones jack, and that it worked on a 7610.
Any ideas of this enhancement for n-gage?
Googled it and everything but I couldn't find it.
dookados wrote:I want some pictures of that.
yeah its the ADA-2 adapter that came with the ngage i have it but i dont have the pop part bit of it!
