How do you change to homepage icons (the 3 big picture test ones) WHen I did my flash upgrade the icons changed and are now in german? I click preferences under home and then click content tab and go to a web page but I can;t read it. there has to be a easier way to change them.
If you're referring to the "home" application buttons.
You just click the preferences in the "home" menu
And then click the Applications tab and there they are.
That is. If i haven't misunderstood you.
I dont think you can change them
if you click on home/preference/content and then the uodate button it will take you to a 3 web page telling you that they chose them and enjoy
