Problem In Sending .mid Files
4 replies · 1,998 views · Started 06 October 2004
I have a problem when i want to send a midi(.mid) using my Bluetooth or thru Infrared.It seem like unable to send out off my 6600 as the searching doesn't appear after i click to send thru any of the device.
:con?
I assume your firmware version (*#0000#) is 4.09.1,so that's why you can't send midi,sis,awb,jar etc files.It's because pf copyright protections (though it's sounds silly about the midis)So the solution is to rename the extension of the midi file: *.mid_ ,and the phone will allow you to send it via BT
Bulgaria wrote:I assume your firmware version (*#0000#) is 4.09.1,so that's why you can't send midi,sis,awb,jar etc files.It's because pf copyright protections (though it's sounds silly about the midis)So the solution is to rename the extension of the midi file: *.mid_ ,and the phone will allow you to send it via BT
If this Solution Does't Solve Your Problem. Then try to Upgrade your "Firmware" to v5.01. Something.Take Your phone to Nokia Care Center.
bryan3928 wrote:I have a problem when i want to send a midi(.mid) using my Bluetooth or thru Infrared.It seem like unable to send out off my 6600 as the searching doesn't appear after i click to send thru any of the device.
:con?
Have you tried sending midi files using FExplorer?
I think you can send via BT/IR even copy righted midis using FExplorer
jazzy1 wrote:If this Solution Does't Solve Your Problem. Then try to Upgrade your "Firmware" to v5.01. Something.Take Your phone to Nokia Care Center.
Very impractical if u ask me, just rename the midi using a file manager as mentioned above rename into anything if it doesnt play back on the recipients phone after transfered browse through the systems mail folder and rename the file back to its original extension name.
