A few weeks ago I installed the eProfiles Demo. Now the testing time is over so I uninstalled it again and now one of my Profiles is missing. Does anybody have a clue what happened?
Profile is missing
Which profile is that? Which profiles do you have listed now?
I got General, Silent, Meeting, Outside (loud) and Pager but there was one more.
There are these 5 Built in Profile Only.
I don't think that there would be any other.
In other model u can create extra but not in 3650
Maybe there is a difference between 3650 and 3660?
There surely was another one. 100%
I customized it and a few time later it was away.
Mac Fly wrote:Maybe there is a difference between 3650 and 3660?
Ok Do one thing.
Is there any option in Profile "CREATE NEW"
If it then u simple create more Profile.
If not then:-
Just Go in the MMc Option BACKUP your phone memory to ur MMC using the option Create Backup.
Then Format your phone to orignal setting by #7370# it will clear your all data and just put on the Orignal setting and orignal files then u can see how many profiles are there.
if still there are 5 then restore the data again using the option in mmc Restore from MMC to Phone.
Thanks for your help. I'll see if it works. If not I have to use another profile...
