Image Uploader
9 replies · 3,532 views · Started 06 October 2002
Does anyone know of (or have) the software or scripts to run a personal image server like the one at club nokia so you can upload images from your phone to it using the Image Uploader?
Here in Austria not even the Nokia image server does work .... they say due to extension works, but that since 3 months .. 😞 ..does it work in other countries? I'm annoyed with what Nokia calls customer service ..
Well I considered writing my own, but need more info. When you select the 'image uploader->upload' from the Images screen, what connection does the phone initiate? Does it form an HTTP POST request? Does it just start streaming the raw data to the server?
Help!
since oh1jty said you needed a mailbox, I guess by mail?
a quick look at http://haavi.iki.fi/roadcam/ gives you the full explenation.
Just a simple script does the trick.
Do these examples actually use the Image Uploader option in the Images menu though? Or do they go through Send->Via Email option?
It's using Send->email option.
It's available in camera mode so it easier to access than Image uploader, which is really crappy.
