downloaded a sis program called "extended theme manager." after the installation finished, the menu locked up. rebooted the phone and now i cant get into anything and it stays at the home screen. when i hold down the menu button for a few seconds, a small window pops up in the corner left and shows a skull.
any help would be greatly appreciated.
thanks in advance,
henry
If u not able to do anything as u have said, then try Formatting
Useful helps : Full phone formatting a 6600!
Here to let everybody how to perform a Full phone formatting on a 6600!
If you encounter situation like below on your 6600,
1. Blank screen phone unable to reboot.
2. Phone only able to boot-up to "Nokia" word screen.
3. Install some program but not able to uninstall it after that.
4. Unable to delete unwanted files on C drive.
Do a Full phone formatting on your 6600 and 7610! as steps below,
1. Make sure you have at least 3/4 charge of battery power left.
2. Backup your contacts list and personal files to MMC memory card or Sycn with P.C.
3. Switch-off your 6600 phone.
4. Press and hold 3 keys; Green dial key, * Star key, no. 3 key on keypad and then press the power on/off to swtich on the 6600 phone. Remember, do not let go the 3 press and hold keys until you see a formatting word screen show! 5. After a few minutes when the Full phone formatting completed, your 6600 and 7610 will back to original system and factory settting.
For more information see Here
This Will Definately Solve Your Problem.
If Not Then Reflashing is the Last Choice.
jazzy1 wrote:This Will Definately Solve Your Problem.
Have u tried killing the process with the C button? If you can boot when u hold the menu button a skull appeard cant u kill it, or have appman kill and close all apps?
From my understanding u can still boot but it freezes.
If u installed on MMC take out the MMC then reboot. Try booting in safe mode as well. I dont think this is a virus just some bugy program.
Kamalayan wrote:Try booting in safe mode as well. I dont think this is a virus just some bugy program.
Safe mode? how? on a 7610? chuckle. 🙄
hhmmm, I just read on some other forum on this site about holding down the pen key while booting for safe mode. I cant tell though if this has worked on mine (not that I need this safe mode, I am just curious) as I have nothing that starts up really.
I could autostart agile maybe. Hmmm.
Nyxmorph wrote:Safe mode? how? on a 7610? chuckle. 🙄
Not a 7610 user so ive no idea, just the conotation that mine, a 3660 of lower symbian OS does have the ability to boot in safe mode. 🙄
Hi all, I also got the same problem like pdog. Then I try the full phone format and it worked. Everything back to normal but I lost all my downloaded program. Still it is better than having a dead phone.
Rudyn
