Need help with few problems in my 6600
6 replies · 2,288 views · Started 07 October 2004
Hi
I got my 6600 almost two weeks ago. This is a great phone but I need your help with solving few issues :
1. Auto Key lock - This is a must have feature that I think I do not have or at least could not find. Can anyone help here?
2. Email - I tried ActiveMail and it doesn't work so well. Amy other recommendation?
3. Earphone problem - Well I know it is a sirious problem but has anyone found a solution? whenever my BT headset is connected, I can not hear the ring. It plays only in the headset.
Thanks in advance.
RonenB wrote:Hi
Thanks in advance.
There is no feature for the autokey lock, but I found this small program "Keylocker" and it is great, does everything I wanted to do. Here is the link:
http://www.handango.com/ampp/store/PlatformProductDetail.jsp?siteId=308&jid=79FC2329195C2FB7F4A354X867DXEB5D&platformId=4&productType=2&productId=131236&sectionId=0&catalog=20&topSectionId=-1
RonenB wrote:Hi
Thanks in advance.
1. Auto Key lock - goto... menu/tools/settings/security/phone and sim/autolock period.change the option to user defined and you are good to go.
2. Email - Profimail 1.05 rocks...
3. Earphone problem - i know man...i have the same problem called both the device company and nokia.... they say it is actually a driver fault.
Lay back and have fun.
1. I tried it. this makes you put a 5 digit code to open the keypad. Way to much. This is a feature of every nokia phone ffor years. Why is it missing in thier flagship?
2. Thanks will check it.
3. I heared about this problem from many other users. how hard can it be to fix it? Why are they not doing anything? Can anyone write a registry hack to fix this?
As above,
2, I have been using the inbuilt app for email since my 7650, with no problems, I have never really understood the need for another one. ( although I did try Profimail recently and it did seem slicker, but still happy with the OS one)
