menu key and left select key both do not work
1 replies · 4,301 views · Started 07 October 2004
I have contacted nokia about this problem, and they have taken a month and still havent replied - since then, the problem has worsened.
Basically, I have had little problems with my nokia 6600 since the day I got it, most problems disappeared after a day or two, or only had one occurance.
But a month ago, I started having issues with both the menu and the left select key's - they both decide when they want to work (and they both do not work at the same time as each other)
It cant be a hardware fault, otherwise the keys would not work at all - when they do work, I do not need to press them hard to get them to function as they normally would on any other 6600.
The problem is starting to get really bad though, and sometimes do not work for up to 8 hours at a time - which is a huge problem when trying to key-lock/unkey-lock the phone or use any phone functions.
Does anyone have any ideas on what I may do to fix this problem?
Thanks very much for any help you give in advance.
