sendo X versions
4 replies · 2,474 views · Started 07 October 2004
Hi everyone,
I was just wondering whether someone could clarify the latest firmware version available to the UK sendo x's and, if anywhere, where could the phone be bought that has this latest version?
Many thanks
I think expansys are the first UK distributor to provide the phone but i dont know what version it is as i didnt buy mine from them.
Basically, we just need someone who bought there X from Expansys to check which version s/w they have.
Copied from another thread (posted by Elite):
X 1.72.5.2
Release IG
17-Sep-2004
Pn:8G26-00000-00018
SPN: 0000-00000-00000
(c) Sendo 2004
IG:3.13
IG:Expansys UK 1.10
GSM SW Ver: 04.35
IMEI No: XXXXXXXXXXXXXXXXXX
Product Id: SNDX00
pelwell wrote:Copied from another thread (posted by Elite):
X 1.72.5.2
Release IG
17-Sep-2004
Pn:8G26-00000-00018
(c) Sendo 2004
IG:3.13
IG:Expansys UK 1.10
GSM SW Ver: 04.35
Product Id: SNDX00
Its not actually possible to determine the firmware version from the above information (unless you work for Sendo), but according to plinkykev, this is build 50F & contains a couple of unspecified minor changes/fixes over the previously released non English build (50C).
The latest UK build is indeed 50F (v1.75.2.2). it has, so I'm told, 3 UK specific fixes over and above the 50C update (v1.56).
Whether Vodafone get any extra fixes in their firmware remains to be seen - the phones should be available in stores by this weekend, so I will check it out if I get a chance...
