full screen wallpaper on the 3660
3 replies · 6,418 views · Started 07 October 2004
hi...
is it possible to have a full screen wallpaper on da 3660 (not just a 172x132 image-like in the 6600 ) and is it possible to use themes on the 3660?
also when i use the nokia phone suite...and i try to convert these mp3's to midi for ringtones the suite just shuts itself down..im usin the latest ver 3.0 frm the internet( plus bluetooth for the connect)
any help will be appreciated
thanks
I'm not sure abt some of your questions, but i can answer one-
Nokia 3660 and Nokia 3650 CANNOT have themes like on NOKIA 6600 and NOKIA 7610. This is because Nokia 3650/3660 run under Symbian OS 6.1 and Nokia 6600 and Nokia 7610 run under Symbian OS 7.0
For the wall paper thing, I dont know abt a full screen wallpaper but if you want to put a wall paper in the standby mode, the pixels of that pic shud be 176*132 pixels [thats how my Windows XP Pro resizes them] for it to look like a wall paper from a pic taken by the camera. For an image resizer, you can use a google search.
For the Nokia PC Suite thing, I used Nokia 3660 PC Suite for a short time with my Nokia 3650. I had converted 2-3 MP3's, and they had converted into .wav's. I havent heard of an MP3 being converted into a MIDI file before tho... :tongue:
Instead of converting it, there is an option of putting an MP3 Player on your phone, and loading the Mp3's from the computer to the phone and listening to the mp3's on the phone. Some MP3 players are - UltraMP3, MP3Go.
NOTE - I dunno abt putting mp3's directly into the phone via PC suite, because it started converting it for me, I think you have to click on some option and uncheck some box .
Hope this was helpful
Rohit
thanks for the info 😃 ....true that we cant use themes on a 3660 but is there a 3rd party software which will allow us to have full screen wallpapers?
hav a good one !
the only way I found to transfer mp3 files to your MMC without converting to wav (like pcsuite does) is doing using a memory card reader.
I have one, plug the mmc on and just copy mp3 to the folders I want. that's all.
cya
