Can i set .rm files as my ringtones on the 3660?
Cheers!!
Cheers!!
Deceptive Blade wrote:Can i set .rm files as my ringtones on the 3660?Cheers!!
Kamalayan wrote:Videos? Na ah. 🙄 Only wavs amrs mids and rngs.
Any way to convert these .rm files to wavs?
Deceptive Blade wrote:Any way to convert these .rm files to wavs?
Maybe u could do it the primitve way, that is if no one would answer ur query with a technical solution. Play the file on ur pc and record the sound from your speaker. 😃 Quite garbled but it will work. Or get a mic and record it from your PC sound recorder, save the file to a workable format mono of course , upload done. 😃 😃 😃
Kamalayan wrote:Im not a ringtone fanatic so am not really familiar about conversion.Maybe u could do it the primitve way, that is if no one would answer ur query with a technical solution. Play the file on ur pc and record the sound from your speaker. 😃 Quite garbled but it will work. Or get a mic and record it from your PC sound recorder, save the file to a workable format mono of course , upload done. 😃 😃 😃
I think this is the only option ive got now. Thanks!!
Deceptive Blade wrote:I think this is the only option ive got now. Thanks!!
Thanks Brother.
i know realone can play .rm files... try it!
or get a .rm converter
<a href="http://www.rmconverter.com/download.html"> here </a>
you convert it to mp3.
ripley wrote:i know realone can play .rm files... try it!
<a href="http://www.rmconverter.com/download.html"> here </a>you convert it to mp3.
