help!! does anyone know how to put photos back onto a P900 from a PC when using USB connection.
I've managed to delete all my bosses photos from her phone and have no clue how to get some important ones back on there.
any help would be useful
thanks
thanks
If PC suite is installed, just click on the "My P900" icon, navigate to one of the images folders and then copy and paste them into there. If not, then you're going to have to rely on one of several options.
1/ Is there are memory card reader on the PC? If so, you can use that to write the photos onto the card in the phone
2/ Does the PC have IR or bluetooth? If so you can beam the photos onto the phone.
3/ Is your boss's phone set up with e-mail? If so, the photos can be e-mailed to that address and then downloaded onto the phone (expensive option though).
I think that's it.
