Editing Existing Themes?
0 replies · 1,698 views · Started 08 October 2004
I just downloaded the Nokia Theme Editor and have been trying to figure out if it is possible to edit existing theme (.sis) files.
I can view an existing theme in the gallery, but 'Edit' is not available. However if I select "New Theme" and then go back to the existing theme, I can now edit and save it. However, it does not save to the default location and the .tdf file that it does create will not open.
Is there a surefire method for editing an existing theme? Or do you have to take apart the .sis and then .mbm files and recreate it (painfully) manually? :con?
Thanks for any info.
Steve
