How to convert Windows Media Audio file in any compatible format for nokia 7610?
like to convert in Wav or in mp3
so i can make then as ringtone in my phone.
All you need is a wave editor such as 'Nero' that supports .wma format then its simply the same creating a wav from Mp3. 😊
I am using NERO V 6 it is saying No compatible file found When i try to write Mp3 or Audio Cd.
Vicky wrote:I am using NERO V 6 it is saying No compatible file found When i try to write Mp3 or Audio Cd.
Any other Solution for creating .wma to Mp3 or Wav.
Just search google for WMA to MP3 converter.
BPS audio converter
I use nero 6 wave editor to open wma's and its saves them as mp3 or wav,no problem at all!!! 😊
But my problem is sloved i am using Advanced Wma Workshop.
