My X is completely hosed (Now screen has lost all panes except My Pane, menu takes about 1 minute to appear, soft keys never respond).
I have tried to reset it by dialling *#7370# and entering 12345 as the phone code. When the phone finishes turning off and I turn it back on it is exactly as it was before the reset attempt.
I have also tried to reset by holding the 5 key whilst turning the phone on - The phone just turns on, I don't get any green tick mark on the right soft key.
Does anyone have any suggestions for what I can do to fix this before I throw the phone in the bin and buy a MS SPV C500 instead?
This is really frustrating as the X worked almost flawlessly for about 4 weeks. It only got screwed up when I tried to back it up over USB.
Thanks in advance for any suggestions.
P.S. I just tried to reboot it in Update Mode. Needless to say that didn't work either.
reinstall firmware
then startup with 5 button.
if that doesn't work
reinstall firmware again, again AND again 😊
SPEEDMAN wrote:reinstall firmwarethen startup with 5 button.
That's what I was trying to do when I tried to restart in Update mode.
Is there a way to update the firmware without starting the phone in update mode?
nope
so update mode can't be reached anymore ?
SPEEDMAN wrote:nopeso update mode can't be reached anymore ?
No. So I guess it really is screwed. This has pretty much put me off Series 60.
Hey, it's working again!
I removed all the installed software and then rebooted and managed to get it into Update mode.
So it looks like one of the progs I had installed was stopping the phone from booting into update!
manually removing everything is also a solution ofcourse 😉
from what i've noticed, the worst programs are: FScaller and mobiluck
happy to see yer sendo works again 😊
unhappy to say that many problems don't find cause in the X, but in the software
All the software I've tested from Psiloc also causes BIG problems on the X - stear clear of their programs if you can.
What's bad with FSCaller? I only noticed, that it is importend to switch off the FSC for backup (because of the running process in the background (like autolock for example)).
If you look for a good (and free 😉 chat software for your phone, try SubliMobi bluetooth chat
