I am using my X on the Orange network in France. I did the OTA configuration etc, and when I go to use the web browser (i.e 'internet' option in the menu) I am given the option of different types of connections to choose from (Orange GPRS, Orange GSM, Orange GPRS ACTE etc etc) I have tried all of them but none of them lets me connect. I am on Orange's 'Pro' plan which allows for data connectivity and am kind of lost. Any help would be great...
Thanks!
Daniel
GPRS is the internet connection
get the settings from your provider.
they can send you in SMS
dm1 wrote:Hi,
I am using my X on the Orange network in France. I did the OTA configuration etc, and when I go to use the web browser (i.e 'internet' option in the menu) I am given the option of different types of connections to choose from (Orange GPRS, Orange GSM, Orange GPRS ACTE etc etc) I have tried all of them but none of them lets me connect. I am on Orange's 'Pro' plan which allows for data connectivity and am kind of lost. Any help would be great...Thanks!
Daniel
First thing to do is double check with your network service provider (Orange France) that your mobile number has been provisioned both for GPRS and GPRS ISP access (often they "forget" to provision for ISP access over GPRS). Then ensure you have the correct configuration settings on your phone.
Should be OK then.
thanks for the replies, I will check with Orange!
