Hi
Is it possible to get the phone to ring longer before it switches over to the answer machine.
Hi
U r using the 3rd party application "Answering machine" or u r taking abt Voice Mail Box.
Well abt the 3rd party appliaction
there is a providion that after wht time u want to put ur call on answer 5sec, 10sec,20 sec etc
and abt the Voice Mail Box. When u go in the call divert Divert the call"If not Ansered" it will also ask for time from 5 sec to 30 sec, and if u select 30 sec then your phone will ring for 30 sec and after 30 sec it will transfer to Voice Mail Box.
valian wrote:HiIs it possible to get the phone to ring longer before it switches over to the answer machine.
I had this problem and phoned t-mobile and they upped the time to 30 seconds, I presume your service provider will do the same 😊
Dear all,
How come, all files that ttrasferred to my n7610, cannot be resend (it says, protected files).. even a small sound files.. help me to unprotect that, tks a lot..
Just Re-name the file for eg:
Bloom.mid rename it to bloom. and then try.
