Is there somekind of Registry fixing kind of software for 6600?
5 replies · 6,180 views · Started 10 October 2004
Like cleaner or something 😃
Maybe a program that would compress or move the INSTALLs folder to the MMC and retrieve it if you want to uninstall something. Cause they're really of no use unless u want to take out the software. Although you can do this manually, but smart phones are all about automation right? 🙄
I think you need to delete unwanted files on your cell..Otherwise use registry cleaner software to fix errors....You can try this .....
