How can I remove a software from my cellphone Nokia 3660 ?? if you can help me send me an email. thanks - [email][email protected][/email]
removing software
OoOhHhNiN wrote:How can I remove a software from my cellphone Nokia 3660 ?? if you can help me send me an email. thanks - [email][email protected][/email]
You go to the tools folder, click manager and locate the name of the program u want to uninstall then click Options then remove. For java games/apps go to the games folder, apps, then locate the game, same thing, Options then remove. Easy like abc... 😃
